I have a 1987 Catalina 30 Mk II with the Universal M25XP diesel. Even when the batteries are fully charged, the starter switch will not crank the engine. I was able to jump crank the starter by placing a screw driver across the positive leads on the starter. So I figured bad starter switch and replaced it. Still no Luck. I get no starter at all when I hit the glow plug and starter button. If I jump it first and run the starter for a few seconds, then the switch at the helm panel works ok. Now my new screwdrivers look like a beginners welding project. I think the answer is the wiring harness upgrade,
but I can't find the link in the archives.
