James Marohn
Noticed that two of four bolts attached to the strut is leaking... The nuts were fairly loose so I tried tightening them but all it did was slow the leak.Any suggestions to stop the leak short of hauling her out of the water?I understand that this may actually be a symptom of a larger problem...the engine mount may be misaligned. Excessive vibration from the engine could have rattled the bolt (with the loose nut) quite a bit, enough to make the hole bigger than the bolt was deisgned for...Or is my mind a rambling fool?Anybody else experience similar situations?Tina & James MarohnPerelandra - Seattle
