strut bearing
paulj
Mar 16, 2007
1,361
Catalina 310 Anacortes,Wa
How many engine hours on a strut bearing before replacement?
paulj :cry::troll:
Sep 29, 2009
76
2005 catalina 310 gig harbor, Wa
What no pictures Paul? I just inspect mine for wear each season.
Sep 29, 2008
1,933
Catalina 310 #185 Quantico
No one really knows how many hours
Best way is when you haul out, wait for a cool day, grab the shaft and see if it rattles around. If it doesn't you are just fine. :D
Of course, if you think your local boatyard really needs the work, you can just have them do the work. :doh:
Nov 18, 2010
2,441
Catalina 310 Hingham, MA
When we bought our boat in 2010 the bearing was the original and needed to be replaced. Ours is a 2001. This past winter when I was doing the dripless, transmission coupling and shaft it had a little bit of movement to it. So I replaced it because part was only $45 and it was easy to access.
I was told that you should expect about 5 years out of a good bearing.
Nov 18, 2010
2,441
Ohh. Had about 425 hours when I purchased the boat. We have about 740 right now. So we put almost as many hours on in 4 years as the original owner did in 10 years.
Mar 6, 2008
333
Catalina 310 Scott Creek, VA
Replaced cutlass bearing when I bought boat used in 2006 (48 hours) and replaced again last year (around 675 hours).
Jan 4, 2006
6,928
paulj :cry::troll:
1700 hours at present and not a trace of radial play.
Any theories out there, for ocean going boats, as to why some go sooner (often much sooner) than others ? ? ?
Aug 24, 2009
444
Catalina 310 Sturgeon Bay, WI
Guess it depends on what you run into. We replaced at the start of the 2013 boating season, with 340 hours on engine. In fall of 2013 had to replace again as it was torn up by fishing line wrapped around the prop shaft and pulled through the bearing.
I'm still considering a prop shaft cutting blade.
s/v Long Story
pk104
Jun 30, 2009
208
Catalina 310 Atwood Lake
After getting wrapped up with fishing line twice in one season I installed a Shaft Shark from AB Marine and have not had another problem. There is no way to know if it has cut anything or not but at least I feel like it will. I also have a Gori folding prop from the same company that I am very happy with.
