Strong Track works for me
Bob,I have struggled with the same problem for my first two years of ownership. this spring I reluctantly installed the Strong Track.So far, it works great. But the first year I had the boat, I didn't have much trouble either. Well, maybe toward the end of the first season it was starting to get a bit sticky coming down. I also use a power winch to raise the sail, and it does lug down near the top.My sailmaker gave me a 15-20% discount this spring in his busiest time, but his charges for the sail adjustments (installation of new slides and adjustment to length of the battens) consumed the entire discount. The bottom line was that the entire job basically cost me $25 per foot of mast. If I had the time this spring, I would have installed the hardware on the mainsail myself. It's not rocket science and there is no sewing involved.Price aside, I am very happy with the performance. The sail drops like a rock- express to the deck!! I have the Dutchman Flaking system on my sail and after dropping the main, I just have to straighten out a couple of the flakes and I'm done.I see no reason why the Strong Track won't continue to perform in future years. IMO, the trick is the type of track material and the pollished stainless (oversize) slugs.Although it is expensive, it is less than other systems and it is simpler. Simple is good in my book. Realistically, Hunter should have included this system as standard equipment on these boats, but the price would still be there. If I had realized that I needed it, I would have put it on at the start. I just didn't know.I'll bet you can get a discount on this system at the boat shows. Good Luck. If you want detailed photos of the track to mast installation, send me a note and I'll post them on the Photo Forum.Rich
