Stripped screws in plastic
NYSail
Jan 6, 2006
3,156
Beneteau 423 Mt. Sinai, NY
So I have a fuel sender in my plastic fuel tank….. solid plastic. threads over the 19 years are a bit stripped. What would you do to tighten them up short of tapping new holes. Also don’t want to drill sender to use larger screws. Add a tooth pick to each screw hole then tighten down?
Greg
NYSail
Jan 6, 2006
3,156
Not sure how the toothpicks will react to diesel, so probably not a good idea.
The screws don’t go through to the inside of the tank….. where the sender is, the plastic is thick.
Mar 26, 2011
3,842
Corsair F-24 MK I Deale, MD
Try closing the holes up with a plastic welder, or even the heated head of a large common nail. A few small bits of polyethylene as filler might help/be needed.
If the sender is round (most are) can't you just rotate it and drill new holes? Easy.
NYSail
Jan 6, 2006
3,156
The sender is a hard brittle looking plastic. Dont want to risk breaking it if I drilled. Otherwise I would have just got screws 1 size larger…..
I like the idea of polyethylene bits or strips put into the holes…..
Mar 26, 2011
3,842
If the polyethylene plastic is so hard and brittle looking you are afraid to drill ... you need a new tank before you have disaster. This is obvious. Either the plastic is not that brittle or the tank is cooked. Might as well decide now.
Likes: LloydB
NYSail
Jan 6, 2006
3,156
No... when I first read i thought I read "drill the holes" larger in the sender for a bigger screw (which I wanted to do)..... the sender is the brittle hard plastic, tank is fine. But when I actually read what you wrote I realized you meant rotate the sender and drill new holes into the tank..... perfect idea and wish I would have thought about it this past weekend when I had the this apart and cleaned.
Good news however, is that I got the sender to work (was only reading full) and now know where 10 gallons left in the tank is on the gauge!!.
Mar 26, 2011
3,842
That makes a lot more sense:). Polyethylene doesn't get brittle like that unless it is in the sun.
Mar 26, 2011
3,842
IME, once threads in plastic are stripped, they are stripped. Wrapping or filling with glue that won't bond well to polyethylene is not going to reinstate any reliable degree of hold. Obviously, this depends on the plastic and the situation.
What does help is not stripping them in the first place. This is done in several ways:
  • Make sure the fastener is clean.
  • Don't over tighten. The plastic is many times weaker than metal.
  • Don't cut new threads when reinstalling a fastener. Very lightly turn the screw in the reverse direction until you can feel the existing threads, and then feel it into those threads. If you cut new threads each time, the hole will be ruined on the 2nd or 3rd cycle.
You've got to be gentle.
