The stripes are vinyl.
Joe:The stripe below the toe rail is also vinyl. I tried using the eraser on it. It does take it off but it is much thicker and takes a lot more time. If you decide you want to remove it, I would suggest that you try some of the 3M remover or some Island Girl pink. This should make it easier to remove regardless of what method you end up using. I removed 7/8 of one side with an eraser. I am going to try the hair dryer/heat gun routine on the other side and see how that works.I suggest that you remove them and see what the boat looks like before you get excited about replacing them.
