Stripe Curling
600
Hunter 23.5 Indian Lake
The top blue stripe under the rub rail is curled a bit in a spot or two . I replaced these a few years ago and someone got carried away with a pressure washer and caused this problem . Does anyone know of a product that I can use to (glue?? ) the stripe back without replacing the whole stripe ?The area is maybe an inch long .Thanks as usual , Mike Bacome
C
Chris
Spray Adhesive 77
by 3M will do it. Mask off all around the area to catch over spray, give the hull under the tape and the back of the tape a quick shot, let the glue dry and then smooth the surfaces together.
