Stretching Antifouling
Dec 11, 2015
306
Hunter 25 Plymouth
I realize I'll be told not to experiment or cheap out on painting my boats bottom however there's the fantasy world and the real world and mine includes the usual expenses such as a mortgage and the unusual expenses such as my daughters college tuition, so stretching is my only choice.
I have half a gallon of antifouling from last year which I guess means I used half a can at the last painting. I may be able to make it however I have a can of topside red paint (same color as antifouling) and some paint thinner. I thought I would add the topside paint and paint thinner to the antifouling. I realize this may compromise the abilities of the antifouling however any constructive opinions on this need is appreciated!
Thanks,
Mark
Gunni
Mar 16, 2010
5,937
No. What kind of antifouling paint are you using? Ablative or hard AF? Many ablative do not need to be reapplied, just touched up.
7,336
Alden 50 Sarasota, Florida
You might be the first to try that.
My guess is that the carrier solvents are different making it impossible to create a homogeneous mix which likely will result in uneven distribution of the antifouling.
You would be better served by simply diluting the antifouling with the same or compatible carrier solvent and put two coats of the diluted mix. Or just buy some cheap antifouling paint.
Likes: Gifforst
I see you have a 25. Are you trailer sailing or leaving it in a slip? I feel that trailer sailing does not require anti-fouling paint at all. If leaving in a slip... what @Gunni said.
Feb 10, 2004
4,096
Hunter 40.5 Warwick, RI
I vote for a touch-up. Mixing potions could cause problems far worse than the expense of more bottom paint IMHO. Speaking of frugal, I have for many years IGNORED the bottom paint instructions to apply two coats with a 3/8" roller. Instead, I apply one coat, just as thin as I can and still cover, with a 3/16" roller. I paint every year after sanding and a solvent wash, and I do not get build-up that will eventually chip and flake. This year I used 3/4 gallon on my 40 foot sailboat, but depending upon the individual paint, I have used as much as 1-1/8 gallons. Prior to this procedure, I applied two heavy coats per the manufacturer and had terrible build-up and massive chipping.
This is just a suggestion for future planning.
Oct 3, 2014
261
Marlow-Hunter MH37 Lake City, MN
The application instructions for the ablative paint I used, Pettit Vivid, indicates that you can add up to 10% thinner. I did this for my second coat and I think I got more than 10% additional coverage with that 10% thinner.
I've never kept a boat in FL but around here I have gone two seasons without re-applying ablative paint and two seasons with hard paint (Not the same boat). I do clean the bottom regularly during the season. As said above you could just touch up where the paint has worn thin, typically the leading edge of foils and hull.
Aug 2, 2009
651
Catalina 315 Muskegon
Sounds like rolling the financial dice. If money's tight, why put it ask risk? If your paint mix doesn't work well, the fix will not be fun or cheap.
Dec 1, 1999
2,391
Hunter 28.5 Chesapeake Bay
I do exactly what Rich Stidger describes above: One thin coat of ablative (I use Hydrocoat) using a smooth 3/16th roller each year. No fuss, no muss, no sanding, no buildup. And no hardgrowth on the bottom. Water based Hydrocoat can be thinned a bit with plain water. A half gallon should be plenty for a 25-ft boat. Figure the amount you need this way (most gallon cans of bottom paint typically cover 400 sq ft): Length at waterline x max beam x .85.
I don't think any good could come of mixing the antifouling with topside paint. The risk is more than just losing the antifouling properties - if (when) it doesn't work you'll have to sand off all the topside paint on the bottom. Half a can should be plenty of thinned with the proper solvent. Use a 3/16" roller as other as others have suggested to get a thin coat. Start with the leading edges and waterline. If you run out getting to the bottom of the keel or some other out of the way place then the existing ablative will probably still work.
capta
Jun 4, 2009
4,905
Antifouling paint has a shelf life. I'd get the product data sheet before I applied it to make sure you aren't just wasting your time putting on paint that won't antifoul.
Aug 3, 2012
2,542
Do not mix them. They are two different paints. The topside paint may well FEED the very organisms the antifouling paint is trying to prevent. Additionally, topside paint is definitely not formulated for use below the waterline.
I also agree that 1/2 gallon is enough for a 25 footer. If you find that it evaporates and dries fast in the roller pan, try putting the paint in a squirt bottle and squirting it on the foam roller.
You should powerwash carefully and look for thin spots where you can see the Interprotect through the paint. Those are spots on which to focus. I get multiple seasons out of VC17m with a powerwash and some touch up. I realize you aren't using VC17m, but the idea is the same.
Dec 25, 2000
5,900
Just got my annual diver report where he says that the two coats of ablative that I applied six years ago is thinning. He did his usual checks, scraped mussels off the keel and a few barnacles from the bright work. Shaft, strut, prop, though hulls, rudder and speed transducer all in good condition. Belle-Vie ready for another season of sailing around PNW waters with new shaft zincs.
Oct 2, 2008
3,810
Pearson/ 530 Strafford, NH
Sitting here in Beaufort, NC I just had the bottom cleaned. While doing so I asked the divers about growth in this area. "Oysters and Barnacles depending on how close you are to the bottom." was their reply. "The next marina over has more algae and other growths." In Plymouth your needs will be different than what I get in Maine. Talk with a paint rep at a boat show and ask about performance specific to your area. Better yet would be a local diver that's cleaning boats in the water. I've used left-over paint on our former boat to touch up leading edges and had good results. Now I'm using white over a green signature coat. When the green is showing, it's time to paint.
All U Get
Jan 27, 2008
3,086
ODay 35 Beaufort, NC
All U Get, curious what brand of paint you are using that comes in white? I paint my rudder white so it doesn't get as hot when baking in the sun when the boat is on the hard, and makes it easy to see if it is clean or not. I have only found Vivid in white around here. I just get a quart since it is just the rudder but a quart is over a hundred bucks with tax.
Beneteau 323 Annapolis MD
For you Annapolis skippers, The Hillsmere True Value Hardware on Forest Drive has a good close-out sale on Micro bottom paints. They really cut back on their boating stuff, so maybe they will not carry paint after this sale?
Nov 26, 2012
2,315
Catalina 250 Bodega Bay CA
My hull has ablative paint and it is a trailerable used much as Plymouth uses his. I definitely need bottom paint. I spray with fresh water when boat comes out in the fall, remove any loose growing grass and do NOT scrub the hull and remove the slime and a part of the ablative paint as well. My hull bottom has not been repainted since 2012 and is in great shape. My contention is the dried slime becomes a retainer for my ablative paint and in some way helps it oppose long growth as well as barnicles and other varment attachments. It appears that I am not losing much or any of my ablative paint. The only part of my boat that gets much long growth is the rudder. Chief
4,096
I used to do this but now I paint with my blue bottom paint. When on the hard, I cover the rudder with a piece of white shrink wrap that would have been recycled anyway.
