- Dec 25, 2009
- 269
I have built my own motor mount and until this past weekend it has not really worked as designed. I could not get enough lifting power to get the motor out of the water when sailing or at the dock. My rigging was not the best. The prototype was crude and did not have good blocks or enough of them.
Finally this weekend, I rigged a 6:1 lifting system. The cable goes to the top of the mast and is separate from the the back stay I got it the same time as I got my new fore stay. Well, I hooked everything up and tried to hoist away and nothing happened. I shifted the position of my upper blocks to be directly above the eye bolts and hoisted away again. Success...
Now after all that, here is the issue. The motor weighs around 80 lbs, and even with 6:1 it seemed very heavy and seemed to put an awful lot of tension on the mast. The back stay bowed loose.
Is using the mast in this way to lift 80 lbs to much pressure?
I don't have a mast post. The mast is cabin top stepped.
Here is a pic of how is should go. Mine has blocks for the lines to go through rather than over the bars like these do. This is not a picture of my boat. I forgot to take any yesterday. It was to darn HOT!!!
What say you???
What say you???
