The construction of the deck/hull joint on my H-376 is that the deck edge rises up in a 3" diameter 'D' shape to form a toe rail, thereby saving the need for an aluminium toe rail. See attached pdf of crossection of what I believe it to be.
Right from new my boat developed lengthwise stress cracks in the fibreglass toe rail. I had these treated by the dealer under warranty in the first year though I don't know what they actually did by way of a repair.
The present position is this cracking is back with a vengeance and this time for much of the perimeter of the deck. I have asked the opinion of our local repair company who say the only cure would be to grind all the gel coat off and some of the laminate and then to build up the laminate significantly thicker than previously. Then to take down the head-linings internally and reinforce the hull deck joint. They reason it is all flexing when people walk about on the deck.
Obviously this is a major job and will be very expensive and even then it is only to overcome the very visual horizontal cracks in the gel coat on the turn of this piece of deck moulding. I don't think that there is any danger of structural failure.
I am reluctant to believe that my boat is the only one to suffer this problem as they all appear to use the same construction.
Does anyone else have this and, if so, how did you remedy it.
Thanks in advance - Donalex.
