Hello sailors,
Has anyone else experienced this problem?
For lack of a better name I’ll use “keel pocket”. The H376 has a bilge that is about 2’ deep, to which the keel is bolted. The keel does not bolt to the “bottom” of the hull.
Does anyone know if the “keel pocket” is a separate lay-up which was, subsequently, fiberglassed to the hull? Or is the “keel pocket“ part of the actual hull lay-up?
My boat is full draft. 5,000 lbs of lead keel bolt to the “keel pocket” roughly 2’ below the “bottom” of the hull.
She is a California boat, originally purchased by a doctor and birthed in Dana Point. To my knowledge, including inspection when on the hard, she has never been aground.
I had her hauled, for bottom paint, etc., last week. I inspected her and found, what I suspect, are stress cracks at the “keel pocket” to hull joint, while she was in the slings.
The cracks are across the leading and trailing ends and extend for 2” to 3” along the sides of the joint. They extend,as hairlines,approximately 14” from the trailing edge Forward. The cracks at the leading and trailing edges, are a maximum of 1/32”. The cracks extending from the trailing edge, forward, along the sides of the joint are hairline. No hairlines from the leading edge toward the stern.
It’s easy to believe that the hairlines are only in the gelcoat. There are several places around “sharp” corners, above the waterline (around windows), where no fiberglas to gelcoat bond exists.
Inspection after setting her on the hard, with a 2 x 10 x 48 under the keel, the hairline cracks can’t be seen. The leading and trailing edge cracks remain obvious.
The fore and aft keel pocket to hull joint cracks are of concern.
I’ve instructed the yard, and one of their fiberglas men, to grind out the cracks (including hairlines) lay-up with the proper Fiberglas material combinations for strength, fair and blend for my inspection, before continuing with bottom paint.
I’m confident that the repairs I’ve ordered will leave “Mer-Sea Beaucoup” safe and sound. I hope this post encourages other Hunter “big boat” captains to personally inspect this hull to keel pocket joint the next time they put their boats on the hard.
Fair seas, following winds.
Tim (Diablito) Hollar
