My temperature gauge on my Westerbeke 44B Four has been acting up lately and no one at Westerbeke can give me the info I need. I'm trying to trouble shoot the sending unit and the temp gauge but no one at Westerbeke can tell me the cold resistance reading (OHM's) I should get on the temp sending unit and what the reading should be a 180 degrees. I am not one of those who just replaces parts until he finds the problem. I much prefer to trouble shoot correctly and in the proper path. In this instance it would be sending unit, wiring then gauge but the folks at Westerbeke are NO help. Does anyone know the resistance I should see when cold on a temp sending unit for a Westerbeke or Universal temp gauge. The panel I have is the standard Universal or Westerbeke panel with volts, tach, temp and oil pressure. Before anyone states the obvious, yes, I have used my infrared thermometer to double check that the temp is correct and it's running at between 176 and 182 degrees consistently even though the temp gauge consistently says it's running at 220 degrees....
