Since I bought this boat used, I don't know if the tiller was straight or curved. A curved tiller was installed when I bought it, and looked to be in very good condition, so probably not original. The PO had a 'tiller tamer' installed, but my attempt to use it with a curved tiller always ends in the rope slipping out of the 'adjusters' on the stern(small black 'plastic' devices where line can be inserted to hold tension). With a curved tiller, the rise is at least 9" from horizontal where it exits the rudder head. I assume shims could be placed under the 'adjusters', but don't necesarily want to do that (although cheaper then a new tiller). I can't really release the tiller to do anyth9ing whether under sail/power as it has a tendency to swing. I need a solution to this, which the tiller tamer would provide if I could make it work...
Charles
Charles
