Stove Replacement 302/322
Jul 12, 2011
148
Oday 302 st pete
Any 302 or 322 owners out there replace (or fix) their stoves? I have the non oven variety made by Tasco I think? The burners are putting out less and less flame as the years go by. Open to fixing, but Tasco has shut down their stove business. Anyone find a suitable drop in replacement?
May 24, 2004
7,164
CC 30 South Florida
Provide the stove model and type. As of August 2015 Tasco stopped manufacturing stoves but there are plenty of parts in the market. They acquired Kenyon Stoves in 1983 and some of the parts may be interchangeable.
Jan 27, 2008
3,086
ODay 35 Beaufort, NC
Less flame seems to suggest a restriction. My guess without any other info is that the burner holes are oxidizing and closing up a bit. Try taking a piece of stiff wire and poking it into the holes to remove any foreign material from the corrosion. Metals that are hot and repeatedly cycled through hot and cold and in a high humidity environment will react with free oxygen and my guess is that's the problem. Otherwise I'd recommend you go with an Origo non pressurized alcohol stove. This gets rid of the dangerous propane, frees up your propane locker, eliminates the electrical and maintenance need for a solenoid switch and hoses and connections. I replaced my Tasco stove/oven with an Origo and am very happy with it. I had an Origo two burner in a smaller boat before and liked it then as well.
