Hi WaltHow can you hoove to on mainsail only ? how do you reverce it and how do you set up your main sail position. I have never heard of this way before. Please describe...Hi TomTo my experience , i had good resaults ...FIRST CASE : heaving to with the jib only (reverced) , letting the boat drift with the stern pointing to the wind and the bow at about 160 deg of the wind. This way there is minimum stress to the rudder , as it works as designed ( the water flow is normal) when the boat accelerates at the impact of a braking wave , and the boat axis sits relatively vertical to the waves , so it is comfortable to. There is no need to reef the jehnoa , as this would firstly reduce its
reverce action and secondly because of its porition relatively to the boat and the wind , the boat does not heel to much. This method is also described at "Thoughts, Tips, Techniques and Tactics for Singlehanded Sailing" book by Andrew Evans , which i once downloaded from this link ...:This book is only available as a free download fromThe Singlehanded Sailing Society at
www.sfbaysss.org/tipsbook " . I imagine that this way , some of the braking waves may enter the coccpit , even if the stern tends to rise above them under the downpressing stress of the jehnoa to the front part of the boat... But this is something to be expected and mostly common also in cases when we use para ancor from the stern ,which is a commonly sudgested tactik .Further more , the boat has the freedom to surf down the slope of the wave if things get to heavy , ruther than role over..And more, your
main does not suffer from flapping , compared to the .................SECOND CASE : heaving to with both sails . To my boat , i reef the backed jib as the wind grows , to avoid to much healing. The same for the main. The two sails have to be counterballanced to make the boat point to the wind at an angle of about 50-60 deg. The very experienced former owner of "Spring Fever " , Bob Carlisle , who now sails his new boat MoonRebel , a Trident 35 , near Panama or Maiami i think , after crossing the Atlantic with his wife Lesley ( greetings to both of them ) , had explained that he could achieve that , ( with the specific sails and setup off course ) only if he would steer the rudder to the wind , as the tecniue requires , but not to the full , he would stop/tie the tiller against a spacer pillow to the windword cocpit seats. As you understand , it can be done , but you have to
practice it and experiment . I have not had the oportunity or the need so far , and if i really had the need , i am not sure i would have the nerve to experiment. I suppose you should build up experience on gradually worsening conditions , to write down the correct set up for a really big storm... ???? 6:11 ?.?. ???????, 6 ???????? 2014, ?/? walt judy brown allore bestvega@... ??????:
Hi Tom, We spent a night hove to in 50 knot winds off of a lee shore with a double reefed main and no jib. When we had our sails made I discussed getting a trysail with the sail maker and his thoughts were that on smaller boats we could probably get away with 3 reef points. When you hope to cruise there comes a time when you quit working on the boat and just go. (Cruising has been defined as working on your boat in exotic places.) I'm embarrassed to say that the sail had been made with 3 reef points but we only had it rigged for two of them. I would have used all three if I could have. We had a storm jib but I was just to scared to go on the foredeck to rig it. At times waves would come over the bow and roll over the boat and on occasion, roll over the cabin and dodger. Cockpit was half full at times. At our next opportunity we put in the lines for the third reef point and 2 extra drains for the
cockpit. It was the second scariest night of my life. Some one once told me that if you wonder if you should put a reef in you should. I look back and think that I should have rigged the storm jib before it got so bad. On the positive side of things, I have a great deal of faith in the what the Vega's are capable of. Walt, Lyric From: tjhfenton@...To:
AlbinVega@yahoogroups.comDate: Sun, 6 Apr 2014 08:45:06 +0100Subject: [AlbinVega] Storm Trysail?
Has anyone used a storm trysail on the Vega? I have been studying Storm Tactics by Lin and Larry Pardy, which I found very persuasive. In brief the theory is, in very high winds with breaking waves you are safest when hove to about 50 degrees off the wind and not fore reaching. The slick caused by your downwind drift confuses the following seas, and tames them like an oil slick. They recommend heaving to under triple reefer main or a storm trysail, (not backed jib). If the wind is so strong that the boat is still making some forward progress, or too far off the wind, they recommend a para anchor. Reminded me of Matt Rutherford's voyage.
I have a storm trysail, but it is rigged for raising in a separate raised track. Has anyone fitted such a track to a Vega mast? Any thought on whether it is worth it? Could the sail be set in the main groove, if I changed the sliders? Anyone had experience of heaving to under triple reefed main, and in what strength of wind? Any other thoughts on heavy weather tactics in the Vega?
Tom Fenton, Beowulf, V2977-- Tom Fenton49 Manor Road, Wivenhoe, Colchester CO7 9LNM +44 7740 928369SV Beowulf, V2977
www.blog.mailasail.com/beowulf
#ygrps-yiv-1828821057 #ygrps-yiv-1828821057yiv5738137012 #ygrps-yiv-1828821057yiv5738137012 --
#ygrps-yiv-1828821057yiv5738137012ygrp-mkp {
border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;}
#ygrps-yiv-1828821057 #ygrps-yiv-1828821057yiv5738137012 #ygrps-yiv-1828821057yiv5738137012ygrp-mkp hr {
border:1px solid #d8d8d8;}
#ygrps-yiv-1828821057 #ygrps-yiv-1828821057yiv5738137012 #ygrps-yiv-1828821057yiv5738137012ygrp-mkp #ygrps-yiv-1828821057yiv5738137012hd {
color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;}
#ygrps-yiv-1828821057 #ygrps-yiv-1828821057yiv5738137012 #ygrps-yiv-1828821057yiv5738137012ygrp-mkp #ygrps-yiv-1828821057yiv5738137012ads {
margin-bottom:10px;}
#ygrps-yiv-1828821057 #ygrps-yiv-1828821057yiv5738137012 #ygrps-yiv-1828821057yiv5738137012ygrp-mkp .ygrps-yiv-1828821057yiv5738137012ad {
padding:0 0;}
#ygrps-yiv-1828821057 #ygrps-yiv-1828821057yiv5738137012 #ygrps-yiv-1828821057yiv5738137012ygrp-mkp .ygrps-yiv-1828821057yiv5738137012ad p {
margin:0;}
#ygrps-yiv-1828821057 #ygrps-yiv-1828821057yiv5738137012 #ygrps-yiv-1828821057yiv5738137012ygrp-mkp .ygrps-yiv-1828821057yiv5738137012ad a {
color:#0000ff;text-decoration:none;}
#ygrps-yiv-1828821057 #ygrps-yiv-1828821057yiv5738137012 #ygrps-yiv-1828821057yiv5738137012ygrp-sponsor #ygrps-yiv-1828821057yiv5738137012ygrp-lc {
font-family:Arial;}
#ygrps-yiv-1828821057 #ygrps-yiv-1828821057yiv5738137012 #ygrps-yiv-1828821057yiv5738137012ygrp-sponsor #ygrps-yiv-1828821057yiv5738137012ygrp-lc #ygrps-yiv-1828821057yiv5738137012hd {
margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;}
#ygrps-yiv-1828821057 #ygrps-yiv-1828821057yiv5738137012 #ygrps-yiv-1828821057yiv5738137012ygrp-sponsor #ygrps-yiv-1828821057yiv5738137012ygrp-lc .ygrps-yiv-1828821057yiv5738137012ad {
margin-bottom:10px;padding:0 0;}
#ygrps-yiv-1828821057 #ygrps-yiv-1828821057yiv5738137012 #ygrps-yiv-1828821057yiv5738137012actions {
font-family:Verdana;font-size:11px;padding:10px 0;}
#ygrps-yiv-1828821057 #ygrps-yiv-1828821057yiv5738137012 #ygrps-yiv-1828821057yiv5738137012activity {
background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;}
#ygrps-yiv-1828821057 #ygrps-yiv-1828821057yiv5738137012 #ygrps-yiv-1828821057yiv5738137012activity span {
font-weight:700;}
#ygrps-yiv-1828821057 #ygrps-yiv-1828821057yiv5738137012 #ygrps-yiv-1828821057yiv5738137012activity span:first-child {
text-transform:uppercase;}
#ygrps-yiv-1828821057 #ygrps-yiv-1828821057yiv5738137012 #ygrps-yiv-1828821057yiv5738137012activity span a {
color:#5085b6;text-decoration:none;}
#ygrps-yiv-1828821057 #ygrps-yiv-1828821057yiv5738137012 #ygrps-yiv-1828821057yiv5738137012activity span span {
color:#ff7900;}
#ygrps-yiv-1828821057 #ygrps-yiv-1828821057yiv5738137012 #ygrps-yiv-1828821057yiv5738137012activity span .ygrps-yiv-1828821057yiv5738137012underline {
text-decoration:underline;}
#ygrps-yiv-1828821057 #ygrps-yiv-1828821057yiv5738137012 .ygrps-yiv-1828821057yiv5738137012attach {
clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;}
#ygrps-yiv-1828821057 #ygrps-yiv-1828821057yiv5738137012 .ygrps-yiv-1828821057yiv5738137012attach div a {
#ygrps-yiv-1828821057 #ygrps-yiv-1828821057yiv5738137012 .ygrps-yiv-1828821057yiv5738137012attach img {
border:none;padding-right:5px;}
#ygrps-yiv-1828821057 #ygrps-yiv-1828821057yiv5738137012 .ygrps-yiv-1828821057yiv5738137012attach label {
display:block;margin-bottom:5px;}
#ygrps-yiv-1828821057 #ygrps-yiv-1828821057yiv5738137012 .ygrps-yiv-1828821057yiv5738137012attach label a {
#ygrps-yiv-1828821057 #ygrps-yiv-1828821057yiv5738137012 blockquote {
margin:0 0 0 4px;}
#ygrps-yiv-1828821057 #ygrps-yiv-1828821057yiv5738137012 .ygrps-yiv-1828821057yiv5738137012bold {
font-family:Arial;font-size:13px;font-weight:700;}
#ygrps-yiv-1828821057 #ygrps-yiv-1828821057yiv5738137012 .ygrps-yiv-1828821057yiv5738137012bold a {
#ygrps-yiv-1828821057 #ygrps-yiv-1828821057yiv5738137012 dd.ygrps-yiv-1828821057yiv5738137012last p a {
font-family:Verdana;font-weight:700;}
#ygrps-yiv-1828821057 #ygrps-yiv-1828821057yiv5738137012 dd.ygrps-yiv-1828821057yiv5738137012last p span {
margin-right:10px;font-family:Verdana;font-weight:700;}
#ygrps-yiv-1828821057 #ygrps-yiv-1828821057yiv5738137012 dd.ygrps-yiv-1828821057yiv5738137012last p span.ygrps-yiv-1828821057yiv5738137012yshortcuts {
margin-right:0;}
#ygrps-yiv-1828821057 #ygrps-yiv-1828821057yiv5738137012 div.ygrps-yiv-1828821057yiv5738137012attach-table div div a {
#ygrps-yiv-1828821057 #ygrps-yiv-1828821057yiv5738137012 div.ygrps-yiv-1828821057yiv5738137012attach-table {
width:400px;}
#ygrps-yiv-1828821057 #ygrps-yiv-1828821057yiv5738137012 div.ygrps-yiv-1828821057yiv5738137012file-title a, #ygrps-yiv-1828821057 #ygrps-yiv-1828821057yiv5738137012 div.ygrps-yiv-1828821057yiv5738137012file-title a:active, #ygrps-yiv-1828821057 #ygrps-yiv-1828821057yiv5738137012 div.ygrps-yiv-1828821057yiv5738137012file-title a:hover, #ygrps-yiv-1828821057 #ygrps-yiv-1828821057yiv5738137012 div.ygrps-yiv-1828821057yiv5738137012file-title a:visited {
#ygrps-yiv-1828821057 #ygrps-yiv-1828821057yiv5738137012 div.ygrps-yiv-1828821057yiv5738137012photo-title a, #ygrps-yiv-1828821057 #ygrps-yiv-1828821057yiv5738137012 div.ygrps-yiv-1828821057yiv5738137012photo-title a:active, #ygrps-yiv-1828821057 #ygrps-yiv-1828821057yiv5738137012 div.ygrps-yiv-1828821057yiv5738137012photo-title a:hover, #ygrps-yiv-1828821057 #ygrps-yiv-1828821057yiv5738137012 div.ygrps-yiv-1828821057yiv5738137012photo-title a:visited {
#ygrps-yiv-1828821057 #ygrps-yiv-1828821057yiv5738137012 div#ygrps-yiv-1828821057yiv5738137012ygrp-mlmsg #ygrps-yiv-1828821057yiv5738137012ygrp-msg p a span.ygrps-yiv-1828821057yiv5738137012yshortcuts {
font-family:Verdana;font-size:10px;font-weight:normal;}
#ygrps-yiv-1828821057 #ygrps-yiv-1828821057yiv5738137012 .ygrps-yiv-1828821057yiv5738137012green {
color:#628c2a;}
#ygrps-yiv-1828821057 #ygrps-yiv-1828821057yiv5738137012 .ygrps-yiv-1828821057yiv5738137012MsoNormal {
margin:0 0 0 0;}
#ygrps-yiv-1828821057 #ygrps-yiv-1828821057yiv5738137012 o {
font-size:0;}
#ygrps-yiv-1828821057 #ygrps-yiv-1828821057yiv5738137012 #ygrps-yiv-1828821057yiv5738137012photos div {
float:left;width:72px;}
#ygrps-yiv-1828821057 #ygrps-yiv-1828821057yiv5738137012 #ygrps-yiv-1828821057yiv5738137012photos div div {
border:1px solid #666666;height:62px;overflow:hidden;width:62px;}
#ygrps-yiv-1828821057 #ygrps-yiv-1828821057yiv5738137012 #ygrps-yiv-1828821057yiv5738137012photos div label {
color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;}
#ygrps-yiv-1828821057 #ygrps-yiv-1828821057yiv5738137012 #ygrps-yiv-1828821057yiv5738137012reco-category {
font-size:77%;}
#ygrps-yiv-1828821057 #ygrps-yiv-1828821057yiv5738137012 #ygrps-yiv-1828821057yiv5738137012reco-desc {
font-size:77%;}
#ygrps-yiv-1828821057 #ygrps-yiv-1828821057yiv5738137012 .ygrps-yiv-1828821057yiv5738137012replbq {
margin:4px;}
#ygrps-yiv-1828821057 #ygrps-yiv-1828821057yiv5738137012 #ygrps-yiv-1828821057yiv5738137012ygrp-actbar div a:first-child {
margin-right:2px;padding-right:5px;}
#ygrps-yiv-1828821057 #ygrps-yiv-1828821057yiv5738137012 #ygrps-yiv-1828821057yiv5738137012ygrp-mlmsg {
font-size:13px;font-family:Arial, helvetica, clean, sans-serif;}
#ygrps-yiv-1828821057 #ygrps-yiv-1828821057yiv5738137012 #ygrps-yiv-1828821057yiv5738137012ygrp-mlmsg table {
font-size:inherit;font:100%;}
#ygrps-yiv-1828821057 #ygrps-yiv-1828821057yiv5738137012 #ygrps-yiv-1828821057yiv5738137012ygrp-mlmsg select, #ygrps-yiv-1828821057 #ygrps-yiv-1828821057yiv5738137012 input, #ygrps-yiv-1828821057 #ygrps-yiv-1828821057yiv5738137012 textarea {
font:99% Arial, Helvetica, clean, sans-serif;}
#ygrps-yiv-1828821057 #ygrps-yiv-1828821057yiv5738137012 #ygrps-yiv-1828821057yiv5738137012ygrp-mlmsg pre, #ygrps-yiv-1828821057 #ygrps-yiv-1828821057yiv5738137012 code {
font:115% monospace;}
#ygrps-yiv-1828821057 #ygrps-yiv-1828821057yiv5738137012 #ygrps-yiv-1828821057yiv5738137012ygrp-mlmsg * {
line-height:1.22em;}
#ygrps-yiv-1828821057 #ygrps-yiv-1828821057yiv5738137012 #ygrps-yiv-1828821057yiv5738137012ygrp-mlmsg #ygrps-yiv-1828821057yiv5738137012logo {
padding-bottom:10px;}#ygrps-yiv-1828821057 #ygrps-yiv-1828821057yiv5738137012 #ygrps-yiv-1828821057yiv5738137012ygrp-msg p a {
font-family:Verdana;}
#ygrps-yiv-1828821057 #ygrps-yiv-1828821057yiv5738137012 #ygrps-yiv-1828821057yiv5738137012ygrp-msg p#ygrps-yiv-1828821057yiv5738137012attach-count span {
color:#1E66AE;font-weight:700;}
#ygrps-yiv-1828821057 #ygrps-yiv-1828821057yiv5738137012 #ygrps-yiv-1828821057yiv5738137012ygrp-reco #ygrps-yiv-1828821057yiv5738137012reco-head {
color:#ff7900;font-weight:700;}
#ygrps-yiv-1828821057 #ygrps-yiv-1828821057yiv5738137012 #ygrps-yiv-1828821057yiv5738137012ygrp-reco {
margin-bottom:20px;padding:0px;}
#ygrps-yiv-1828821057 #ygrps-yiv-1828821057yiv5738137012 #ygrps-yiv-1828821057yiv5738137012ygrp-sponsor #ygrps-yiv-1828821057yiv5738137012ov li a {
font-size:130%;text-decoration:none;}
#ygrps-yiv-1828821057 #ygrps-yiv-1828821057yiv5738137012 #ygrps-yiv-1828821057yiv5738137012ygrp-sponsor #ygrps-yiv-1828821057yiv5738137012ov li {
font-size:77%;list-style-type:square;padding:6px 0;}
#ygrps-yiv-1828821057 #ygrps-yiv-1828821057yiv5738137012 #ygrps-yiv-1828821057yiv5738137012ygrp-sponsor #ygrps-yiv-1828821057yiv5738137012ov ul {
margin:0;padding:0 0 0 8px;}
#ygrps-yiv-1828821057 #ygrps-yiv-1828821057yiv5738137012 #ygrps-yiv-1828821057yiv5738137012ygrp-text {
font-family:Georgia;}
#ygrps-yiv-1828821057 #ygrps-yiv-1828821057yiv5738137012 #ygrps-yiv-1828821057yiv5738137012ygrp-text p {
margin:0 0 1em 0;}
#ygrps-yiv-1828821057 #ygrps-yiv-1828821057yiv5738137012 #ygrps-yiv-1828821057yiv5738137012ygrp-text tt {
font-size:120%;}
#ygrps-yiv-1828821057 #ygrps-yiv-1828821057yiv5738137012 #ygrps-yiv-1828821057yiv5738137012ygrp-vital ul li:last-child {
border-right:none !important;}
