Storm sail or furler
Bill Dunn
I purchased a 1986 Catalina 27 this fall. The boat has harken roller furling. I would like to know if it makes sense to have the storm sail altered. I'm told that roller furling allows one to leave the storm sail home. I never had roller furling on my Tanzer 22. On more than one occassion I was thankful I didn't as the wind was so strong a furler might have been ripped. How dificult is it to remove head sail and add storm sail. Is it worth it? Thanks for any reply.
L
L. Neufeld
adding another sail
I, too, have a Cat 27 (1985 model) with roller furling. When I purchased it, the genoa was on the furler, and the previous owners included a hanked-on jib. I took the jib to a sailmaker and had them alter it to fit the furler. It is not difficult at all to lower one sail and replace it with the other. I find that if the winds are stronger, the boat will sail MUCH better with the jib than with a partially furled genoa. I usually try to make the decision -- jib or genoa -- before I leave the dock. If you also get a second set of shackles and sheets for the second sail, it makes changing sails even faster and easier. I found that it was definately worth it.
Brad Williams
By all means, have the hanks removed from ....
your storm sail and get luff tape added. I'm certainly no purist when it comes to sail shape, but after about 50% reduction in the headsail, you begin to notice it. Also, as you furl in the headsail, you are essentially raising the sail off the deck -- and raising the center of effort......something you don't necessarily want in a good breeze. The storm is lower at the start AND it too can be furled to further reduce sail if necessary. All with a much lower center of effort. As L. says, it's a whole lot better making a sail change decision at the slip. While changing the furling sails isn't all that hard, its a couple of minute job and there are times when you don't want to be up on the bow that long (at least I don't).....it's a lot longer than changing out hanked sails....do it before you leave, or at least as soon as you think that you ought to think about reducing sail.. Brad
