We have lived it in Florida!
The insurance people are going to go after me again, but the best place for a boat in a storm, any storm, is in the water. Find a secluded canal, stream or deep harbor, strip the boat of anything that can cause wind drag, set two anchors aft, and two anchors forward with long scopes. 15 to 1 if you have the room. Make sure your anchors have at least 6, but preferably 10 ft of good heavy duty galvanized or stainless chain rode. Depending on how far inland you can get, have enough slack in the rodes that the boat can rise 10 feet or more from the surge. Make sure that the rodes have chaffe protection. Make sure all of your drain holes are open, but plug the sink and toilet thru-hulls if you can from the outside. In heavy weather the lines sometimes come off inside which can cause lots of water damage. The hurricanes do not normally last a long time, but in a very short time, your boat is going to go through hell, first from one direction, then the other. Although it probably will make little difference, try to position the boat so that it heads into the strongest wind. The north west side of the hurricanes in the northern hemosphere tends to have the strongest winds. Not always, but generally.We have been in Florida since 1984. We went through Andrew, which was the worst by far. Then two "no name" storms that cause tremendous water damage. Last year we lucked out. All of the four storms that hit Florida went just a little north of us. My boats have always stayed in the water, anchored about 15 feet from my dock in a canal about 4 miles from the Intercoastal. The tidal surge during one of those "no name" storms was 8 ft in addition to the high tide, at my house. The dock was 2 ft under water, and the water had reached the first terrace around my house. G_D speed! Take care, and take precautions!Paul
