Thanks
Thanks Ted, I'm really surprised nobody else has encountered anything like this or spoke up about it. The traveler car has to come apart in order to fasten those acorn nuts properly, and when it does, the ball bearings fall out. It can be a big problem. If anyone encounters this, please be careful before you assume the traveler car is easily assembled. My Dad and I nearly drove ourselves crazy trying to save the ball bearings and position the device back into place before we got great advice.Be prepared to catch all the ball bearings under the traveler car. Also be prepared that no matter what you try to do to get pack the bearings back in and run them back on the rail (as the engineer at Garhaur Marine recommended), it doesn't fit. He suggested I send it back to him so he could repack it and he'd send it back on a short I-beam track that would facilitate running the car right back into place. There's far too much hardware in the way on my 99 C28 traveler to simply slide the car back on. The traveler block system and cleats would not permit it, and when I took them off, the plate they were attached to was in the way. When I tried to remove the long bolts holding the track to the deck, they were tighter than I could possibly budge. I'd packed the ball bearings into the track very carefully and slid on a handmade wooden I-beam traveler bar replica to follow Garhaur's suggestion, but the design would not permit it.Fortunately, I got great advice from the owner of my yard. He recommended soaking a bar of ivory soap overnight, and in the morning using it to line the top and bottom ball bearing tracks of each inside bar to the traveler car. Once the gooey soap was set, the balls packed in very easily, and stuck in place incredibly well. From that point, one person held both of them into position on the track, while a second slid the car over those two bars. Once it was in place, screwing back in the 5 bolts was simple. To finish the project, we sprayed out the track beneath the traveler with a garden hose, and rolled it back and forth, and watched the suds roll away.I spent so many hours trying different fruitless ways solving this over the past week, thank goodness I received the advice I did. I was just about at wit's end. I hope this saves the next person who might encounter the same problem.Happy sails!
