Turning off the key won't fry the diodes, since it will instantly drop the field current, and it doesn't disconnect the load from the alternator. This is commonly done to put smart regulators back to the beginning of the charging phases, e.g., in case you think you need more time on acceptance and it's already switched to float.Definitely shut engine down before turning the key. Have you killed the diodes in your alternator yet? You might want to be sure your alternator is putting out now.
That is incorrect, at least for most engines. Turning off the key will shut off the regulator, but doesn't disconnect the load (batteries) from the alternator. It's disconnecting the load from the alternator that causes a voltage spike that ruins alternator diodes. So, while switching a conventionally-wired 1-2-BOTH-OFF switch with the engine running can zap an alternator, turning the key switch off will not. Many people turn the key off and back on to put a smart alternator back into it's initial programming state, in the event they want more ACCEPT mode charging than they've gotten. See my previous reply on this.Turning Off the key switch while the engine is still running may damage the diodes in the alternator.
On our H41DS the fuel cut-off is by solenoid rather than by a mechanical linkage. If you turn the key to the "OFF" position, pressing the "STOP" button (to attempt to cut off the fuel) does nothing. Short of going to the engine bay to manually cut off the fuel, you must press the "STOP" button first and then turn the key to the "OFF" position.I was taught to kill the engine first (fuel cutoff cable) and the turn off the key.
Sort of supports what we are saying…kill engine first, the run off the key.On our H41DS the fuel cut-off is by solenoid rather than by a mechanical linkage. If you turn the key to the "OFF" position, pressing the "STOP" button (to attempt to cut off the fuel) does nothing. Short of going to the engine bay to manually cut off the fuel, you must press the "STOP" button first and then turn the key to the "OFF" position.
I use a “free“version…haven’t had to pay for it. Seems pretty comprehensive. I like the daily briefings for a quick summary.yes
just down loaded wind indicator app - PredictWind.com looks cool didn't ask me for $$ probably see something on my mastercard
the alt continues to produce power until the engine (and alternator) stops rotating .I usually turn the key off first just to avoid the loud noise of the Yanmar panel warning horn sensing that there is no more alternator output. I don't see how this can damage the alternator diodes since the alternator is no longer putting out power. It's when alternator is putting out power and the load is shut off that the diodes can be damaged.
