Stop the raddle
S. Morrow
My new H33 has an in mast furling system. I took the sail off for Winter decommissioning. Now the furling system raddles inside the mast with a breeze 10 knots or greater. I tried to tie it off from the opening appprox 6 feet up on the mast but it did not work too well. Any suggstions?
May 5, 2004
181
Hunter 386 Little River, SC
Buy a cheap sail.....
.... and install it just as you would your normal sail. It dosen't have to be big, or even go all the way to the top of the mast. Just a few wraps around the furler will stop the rattle. Good luck...... Jeff
Doug
Its Your Haylard
Had same problem tie your main halyard to the out haul car on the boom tension it and your done.
