I am a shade tree mechanic that is also new to keelboat sailing, However, I have *never* messed with the internals of an engine. I picked up a 1988 Catalina 30 for a good price and I don't mind a project. It was inspected by the local boatyard service department prior to my acquisition and the owner was told he "needed a new engine" to replace the failed Universal m25xp, incidentally that employee has since been fired. I have aspirations of eventually moving to a different boat and doing some blue water sailing in 5-10 years and would like to know a thing or two about diesel engines. I tried taking a diesel engine course at the community college, but they are few and far between and any of the technical schools are pricey, so instead I picked up Marine Diesel Engines by Nigel Calder, downloaded the rather excellent service manual for the engine and preceded to do my worst...anyyyway...
I got as far as taking apart the top of the engine and removing the heads. I was inspecting the top of the pistons and noticed some fine metal shavings, but inspecting the cylinder liners...nothing seemed worn....the tops of the pistons looked good. I then inspected the cylinder head itself and saw that in the intake port of cylinder 2, low and behold it was full of the metal that belongs in the air cleaner. I pulled that out and the screen that is supposed to hold the said metal part inside the air cleaner is partially wrapped around the valve. I can see how if the engine was running at all, it would have only been running on two of the three cylinders and it would have been a mess.
My question is....do I continue rebuilding the engine, as planned? Disassembling the rest of the block, cleaning it thoroughly and trusting that I don't get in over my head mechanically? I'm keeping a video diary of every step of the way so I can see how everything was assembled. Or put it back together, having "fixed" the problem and see if she runs and leave well enough alone if she does. Also, if I continue rebuilding, do I replace the sleeves? Or do the rebuild without replacing the sleeves if they pass inspection using a bore gauge? Michigan is on coronavirus lockdown, so shop time isn't available for the next few weeks to have the sleeves pressed out and back in.
Thanks for your input. Even though I don't know what I'm doing, I'll post a youtube of the videos if for no other reason than people can see the engine torn down in case they are taking on the project themselves.
