Sandi
We closed all the thru hulls when we left the boat 2 1/2 weeks ago. When we returned and used the head for the first time, whew, what a sulphur smell! After trouble shooting using your book (p. 27 in fact) we know we had critters die in there so we assumed the smell was from anaerobic decay. The smell disapated when we used the head. Now here's the question... is there anyway to "drain" the hose from the thru hull to the head? We follow all procedures you describe in your book and everything is great except on this last visit. We are concerned the sulphur smell will permeate the hose. The previous times we left were for only 2 or 3 days, and did not close the thru hull, then back to sailing we went - no problems. We are considering the following options: 1. Leave the thru hull open making sure the head valve is in the dry bowl position 2. Installing a t-valve with a fixture to permit drawing fresh water into the hose with the thru valve closed (head sink and head intake are seperate) Please advise. Thanks.Sandi
