Still seeking help.
Tom Thayer
Still seeking help with the AC wiring scheme for the back of the large AC breaker. Hunter say's they don't have the diagrams anymore. I need to know what color wire goes on what terminal on the back of the breaker. There ar six terminals, two on each of the ganged breakers that have a single switch at the front for AC main. Thanks
F
Frank Walker
black to black, white to white, green to green.
Tom, If there are three breakers all operated with one handle, the correct wiring is as follows. black from shore power to breaker #1 black to boat panel to opposite terminal on breaker #1. white from shore power to breaker #2 white to boat panel to opposite terminal on breaker #2. green wire from shore power to green wire to boat panel connected together. This will leave the third set of breaker contacts unused. From the rear it should be obvious about the three breakers in parallel, normally which terminal is in and which is out is not critical. If one set happens to be labeled line then they go to the shore power, and load is to the boat panel.
Tom Thayer
Thanks Frank
Thanks for the info. This has been driving me nuts.
