Stiff Rudder 1996 Catalina 28
rogerl
Aug 8, 2021
1
catalina 30 prime marina
Purchased the boat last fall, just lubicated chain and bearing in pedestal, still stiff can not move rudder by hand.
Appreciate any help.
dmax
Jul 29, 2018
1,246
Telstar 28 Buzzards Bay
Make sure the wheel brake isn't tightened down. If that's not the case, you need to determine if it's in the steering mechanism or the rudder itself. It would be best if you can disconnect the steering cables at the rudder quadrant - then it will be obvious which one is hard to turn. You can use you emergency tiller to turn the rudder (and it will be good practice if you've never used it). If it's in the wheel, suspect the wheel bearing, the sheaves or the chain/cable binding somewhere. If it's in the rudder, it's possible the shaft is bent or the bearings need grease/attention.
