Stiff engine accelerator lever
Bob Pezzoli
I have a 1987 E35 Mark 3. The engine throttel lever on the pedistal is very stiff. I have tried lubricating it, without success. Is replacing the cable a workable solution? Any other suggestions?
Jul 19, 2005
113
- - s/v GAIA Great Lakes
Sure you can replace the cable.
The question is, are you sure it's the cable that's the problem. Tom s/v GAIA
N
Nice N Easy
Stiff cable
Like Tom said, replacing the cable will help only if the problem is the cable. You need to first determine what is the problem. I would suggest disconecting the cable from the shift box. If it is still stiff, it's not the cable.
