Lube Trick From Motorcycle Days
A trick from younger days when I had a gagle of motorcycles, disconnect the cable at the shift lever end, take a plastic lunch bag, pierce a small hole the diameter of the outside of the cable, slip it over the cable then tape it closed tight to the outer jacket in essence making a funnel out of the bag, fill the bag with lubricant (wd 40, etc), let it stand upright over night, gravity wil do the rest. Woked fine on my Hunter 31, 1985. P.S. I grew up in the southern tier and miss the Formula One weekends at Watkins Glen.
