Sticky Pump
418
Hunter 33 Metedeconk River
I know this must be a basic question but I am new to owning and maintaining. The pump on my Jabsco head is just starting to become sticky and I would like to avoid any big repair if I can. Someone told me to put some Mazolla cooking oil into the head and pump it through. Is this really a cure or is there a better idea?
Dec 2, 2003
1,637
Hunter 376 Warsash, England --
In my case it was the Piston
My pump (Jabsco) became very stiff after just a couple of weeks despite liberal coatings of silicone grease. Curious I measured the piston (ugh!) and the pump cylinder bore and found that with the "O" ring in the bottom of its groove in the piston it was then an interference fit in the pump bore. So, when the lube had been squeezed away it could and would bind. It hardly needs to seal like this as the pump motion seals it against the top and bottom surfaces of the groove as it goes up and down and the contact with the inside of the bore does the rest. I just made the groove a bit deeper using a file. It only needed a quick go with a flat file being VERY careful not to scratch top and bottom surfaces of the groove. I put self adhesive tape on each side of the file and just used the exposed edge in the base of the groove. I reduced the groove diameter by only about .015". The "O" ring does not need to seal to the inside of the groove as explained above. Since then no need to lubricate it at all - AND it still primes from dry no trouble. I guess Jabsco got it wrong!
Dec 19, 2006
5,832
Hunter 36 Punta Gorda
Lub
You could just take the pump apart and relub it is all it usually takes yearly maintenance to avoid bigger problems. Adding a few drops of cheap oil maybe once a week suppose to help too. The head mistress may jump in and help you out better. Nick
Mulf
Dec 2, 2003
400
Hunter 410 Chester, MD (Kent Island)
You should be able to...
...just undo the nut like circular fitting on the top of the pump where the handle shaft goes in. Squirt some teflon lube in there. Thus you don't even have to see the bottom of the pump shaft. Put it back together and pump a few full strokes to distribute the lube. Much better than oil, which can cause problems in the tank as it lays on top and cuts off the oxygen needed.
