Sticky in Texas
Apr 1, 2013
2
Hunter 26 Austin
I have a Hunter 26 (1998) berthed in TX. All of the original vinyl cushions in the cabin have become "sticky" to the touch. We have tried several different cleaning products in an effort to remove the "sticky" but to no avail. Anyone have a suggestion on how to clean the vinyl that will remove the "sticky"?
arf145
Nov 4, 2010
498
Beneteau 331 Deale, MD
Maybe not entirely relevent to cushions, but I have found that when my shore power cord gets sticky from being in the sun and heat, nothing removes the sticky short of scraping it off--not a real option with cushions. I've tried various solvents and label removing products to no avail. I believe heat can be the culprit even without exposure to UV, which I assume is what got to your cushions. My other data point comes from some garage door wiring I was just messing with in the attic of my garage, a space that gets quite hot in the summer. The wiring was a sticky as fly paper.
May 27, 2004
2,059
Look up "303 Vinyl protectorant". West Marine and others carry it.
There are others out there that may work as well, but I can't remember the trade names. Google "vinyl cleaners/treatment".
Jul 7, 2004
8,534
Hunter 30T Cheney, KS
There might be a boat dealer near you that has some experience with the problem down there. It can get pretty hot and humid below where they get stowed.
Acetone might work, or it could melt your vinyl. Try it on a tiny inconspicuous spot.
Here's a thread from the MasterCraft forum where it sounds like they have had the same problem and came up with a solution. https://www.mastercraft.com/teamtalk/showthread.php?t=67364
I have not tried this but they concluded that it was the plasticizer separating out and it may cleanup with Goo Gone.
- Will (Dragonfly)
Bob J.
Apr 14, 2009
775
Sabre 28 NH
- Will (Dragonfly)
I tried it on some throwable boat cushions that had the same issue, it worked.
In the past I've used it on shore power cords. Cleans it off but they end up sticky again 6 months later.
8,534
They might be breaking down from the sound of it. The only answer may be to cover or replace them.
Jun 2, 2004
3,648
I have the same issue
Only with the teal ones the white ones seem OK
Apr 1, 2013
2
Hunter 26 Austin
Thanks to all for the replies. Working through the solutions will be my first project of the new year. Happy Sailing!!
-na -NA Anywhere USA
On the Hunter 26 cushions as a former dealer who sold nearly a quarter of the production line, Bill Roosa hit it on the nail head, acetone and elbow grease. Just remember not to do that over lexan or other plastic products. That is what I did to include shore power chords of course not plugged in.
