Steve Dion
  • Thread starter Douglas Washburn
  • Start date
Douglas Washburn
Steve: You have commented in the past about filling a pail with hot water, detergent and bleach to periodically flush those wonderfully hidden collection areas in the hull liner. As I recall, you said you poured it in under the V-berth, the ice box and behind the engine pan. Where exactly behind the engine pan? That pan on my boat drains nowhere unless you count the starboard heater hose pass-thru.
Dec 23, 2003
268
Hunter H31 83-87 Captain's Cove Bridgeport, CT
Not Steve but
Open the rear storage cover under the aft berth. Pour there, only hull down there, no cabin liner.
Dec 2, 1999
15,184
Ditto Patrick's comment
Doug: Nearly any place in the aft (under the aft berth will work). I normally poured the mixture near the shaft log or one of the other compartments will work. Anywhere where you do not see the smooth gelcoated liner. It is really best if you take the boat out for a sail to slosh it around. PS: Where do you store you boat for winter storage?
Douglas Washburn
Winter storage...
is not really an issue. The boat stays in the slip year round coming out only once every 3-4 years for bottom paint and miscellaneous r&r.
Dec 2, 1999
15,184
Doug, just curious
Doug: I was just curious. We purchased our Hunter Vision 36 in Stockton, MO. last year.
