My 1980 33 is leaking water from the back of the boat. It is a very slow leak that can be easily held by the engine bilge. The problem is that it seems to me that this water should drain into the main bilge, not accumulate under the engine. Is there an open space clear to the main bilge under the engine? That is plugged up with 24 years of dirt, etc.? If so is there a preferred tool that can be used to unplug it. Thanks,
