On my Beneteau 423, there is a water nipple on the forward end of the stern tube for the prop shaft. Apparently, the nipple is made of brass and it has failed on my boat. When I say failed, I mean that it corroded and broke off at the point where it screws into the stern tube. I have called Beneteau and the Dealer and have been advised to find a replacement at a local Marine supply store. The problem is water squirts in where the fitting broke and I haven't extracted the broken piece that is threaded into the tube. Has anyone experienced this issue before? If so, do you know the size and thread pitch for the Brass nipple? I would like to buy the replacement to have on hand when I extract the broken piece.
I currently have a piece of rubber compressed with a hose clamp to keep the water at bay.
Thanks,
Rick
Thanks,
Rick
