I had a near-catastrophic failure the other day while motoring my '75 Catalina 30. Found several inches of water on the cabin floor, well outside the bilge. The stuffing box hose had come off the stern tube, allowing major flooding. I got back to the marina using the engine water pump as an emergency bilge pump. When I was able to get the hose back onto the stern tube, I found that it looked like it had been wrenched off violently, and was in bad shape. It's holding for now, but I need to haul the boat and replace it.
Problem is, the hose was new last summer, when I replaced the engine and almost everything associated with it. I used (supposedly) the proper hose, as recommended by the yard where I did the work, and used stainless T-bolt clamps that are still in good shape.
I did some internet searching and found a couple of articles that said the stuffing box and stern tube should be "castellated" or keyed together so the box/hose can't rotate with the shaft, and they described the resulting kind of hose damage I found in mine. My stuffing box and stern tube were not keyed in any way that I could tell. Any words of wisdom, anybody?
I reused the old stuffing box that appeared to be in good shape, and the old hose was also intact, just a bit worn/frayed at the ends, with some minor surface cracking. The new hose was an inch or so longer than the original, which in hindsight, was probably not the best idea.
MAP
MAP
