stern tube size
steven f.
Just trying to get the official size of a stern tube for a 1981 H33. I've measured it but would just like some confirmation that I'm even close. I'm putting on a PSS dripless shaft seal, if anyone has already put one on can you give me the size that worked for you?
Sam Lust
Memory fades----and word of warning
I did the conversion 2 or 3 winters ago and consider it well worth the time and money. (If you haven't bought yet, hold off till you can get it at a boat show. You can save in the vacinity of $50 at a show from Sail-Net (JSI) or the like.) I'm ashamed to admit I looked at the seal less than twice the entire season this year. It's so reliable I put a battery box/shelf in above it because I now have no worries about having to get in there to adjust packings. This is another item I REALY intend on posting to the Photo Forim!) As far as the size, check the archives. I can't remember the size, but at this point I would think Kevin Woody should have the application. Either way you have to measure because there's no way of knowing what Hunter used. Whatever was at hand on the shelf there might have been different than what was there in '83 when mine was built. So check carefully. Now the word of warning. When you do the install look VERY closely at the bolts that hold in the stern tube. On my 1983 33 they were very long and were just making contact with the rubber bellows. A few hours of rubbing would have produced holes and a VERY unhappy Me. I used a small air operated die cutoff tool , (abrasive cut-off) but if you're a patient contortionist you might be able to get them with a hand hack saw. While you're back there take a look at the packing nut on your rudder tube and see how badly it's corroded away. It's likely there's very little left. If so you might want to fix that.
Jim Logan
Second what Sam said about the rudder packing
My 1980 33 has been in thewater since 1980 - had to have a new rudder packing nut made last year as the old one was full of holes - If you have a leak from the stern, and your drive shaft stuffing box is not leaking, that's probably where it is. A lot of 33's have had to have this packing nut on the rudder shaft replaced.
steven f.
lasdrop
Be it good or bad, the original owner of my boat put in a lasdrop dripless shaft seal on the engine's drive shaft AND the rudder shaft. Both have been on for 15 years and the drive shaft is just now leaking. So far not a drop of H2O has leaked from the rudder (so far).
Joe Gooch
"More Information Please..."
Steve, Would you forward me more information about the "lasdrop" rudder shaft seal. I repacked my rudder shaft this year, and it does not leak but I would like to know where I could obtain a lasdrop seal. Also, can it be installed without taking the boat out of the water. joegooch@hotmail.com Thanks
