Got your attention, didn't I ??
Well, sometimes ruffling a few feathers is not a bad thing. The intention was to stimulate the thinking process, and it appears that happened.It appears we have two different people discussing the problem, Steven F. of Pt. Charoltte, Fl, and Arthur of Lake Lanier, Georgia. Steven and his two mechanics have given up after going to a certain point with no resolution. Arthur, on the other hand has found a bent shaft, bent prop and an out of balance condition. These are distinct, identified problems and not in the context being discussed here. Steven however still has his problem even after his mechanics supposedly ruled out those problems from the beginning as any competent mechanic would have. I certainly did not just assume Hunter did it wrong. I have done a good amount of discussion about this sort of thing with people who the boats and work on them, them and have no vested interests. Plain and simple: these boats were early PRODUCTION boats. There is very little on them that is even and symetric side to side or front to back. I've probably done more work on my boat than any three other Hunter 33 owners and I KNOW my hull, and I can tell you there is NO symetry. Chain plate mount points differ port and starboard, Backstay "U" bolt mounting points vary by about 6 inches. Hull thickness at the sharp "V" of the hull half way between the keel and the knuckle varies 3/8" port vs. starboard in a 2" hole. The deck thickness differs 1/2" port to starboard at the same relative point. Ever pull out the opening ports? Nicely cut holes, eh? (Mine must have been cut by a rabid butcher) So, you believe that every engine bed pan was glued in place perfectly and every strut was bolted in in perfect alignment to it. Well, I can tell you they it aint so. My 2GM banged the shaft against the shaft tube mercilessly. Alignment helped minimaly. Swapping the two cyl for a 3 cyl helpd. But I knew something just wasnt't right. After intense inspection and measurement with the boat out of the water I could see that the shaft did not pass through the hole concentricly over it's length. This necessitated the strut relocation.Now. Are there other factors? I think so. Arthur of Lake Lanier Georgia implies that the problem crept up on him. Ageing of the engine would explain this. As any engine accumulates hours it runs less smoothly and develops rough spots. The mounts also wear, allowing the engine to dance around. These factors undoubtedly account for a good bit of shaft banging. I Steven S.'s case I had to assume these factors had been looked at.The bottom line here? once you have exhausted the logical avenues, the obscure and seemingly unlikely has to be explored. And the way these boats were slapped together leads to the obscure and unlikely.Did I look at opening up the shaft tube to eliminate the problem? Of course I did, but I determined that on the 33 hull it would create more problems than it cured and more work than it was worth.
