Hi all,
Having had some trouble with the prop shaft coupling on Pagan Baby this winter I disassembled the dripless shaft seal, removed the coupling, and pulled the shaft. In doing so I noticed a couple of logitudinal cracks in the bronze stern tube that had been covered up by the bellows from the shaft seal.
So now I'm contemplating wraping a couple of layers of glass and epoxy around the broze stern tube to seal/bind the cracks and then replacing the bellows for the dripless system-hoping that will be enough to stop the cracks or limit their expansion. I'm also considering installing a flexible linker between the transmission flange and shaft coupling to reduce vibration, and while I'm at it, replacing the cutlass bearing.
What do people think of flexible shaft couplings-pros and cons, and has anyone replaced the cutlass bearing on their Vega? Has anyone seen similar cracks in their stern tube?
Thanks,
Tom
Pagan Baby V-398
Thanks,
Tom
Pagan Baby V-398
