C
CPT Tom
I want to mount NavPod Stern Rail Speakers on my 2004 Model 260. Looking at the frame, I cannot see where I can carry the speaker wire down inside the SS tubes to enter the hull. The rail attachment points are apparently into solid structure thus not allowing a wire feed down into the rear area underneath the cockpit. Has anyone installed a similar speaker setup and how did you run the wires? Apparently the older 260 models had a different configuration of the stern rails and allowed the wires to be installed inside the tubes and then into the boat.
