Stern Rail Mounting of Tender Outboard
Bruce Cutcliffe
I would like to mount my recently purchased 4-hp Yamaha outboard on the stern rail of my O'Day 26. However, the motor, being a 4-stroke (unable to buy a new 2-stroke in anything under 8-hp)weighs 48 lbs (22 kg)with the internal gas tank empty. I would have prefered the Yamaha 2.5-hp (also a four-stroke) that weighs only 37-lbs, but doubt if 2.5-hp would be adequate for my 9'4" inflatable. I know 48-lbs does not sound like much weight, but I am concerned with the weight on the stern rail. The O'Day 26 has a single stern rail. There are two supporting T-rails, but no lower rail. The small internal gas tank, when full, would probably add an additional 1.5 to 2.0 lbs. If necessary, I could probably exchange the motor for the 2.5-hp model as it is brand new. There is not really any other acceptable location to store an outboard on the sailboat. Any recommendations would be much appreciated. Thanks, Bruce C.
pbud
outboard bracket
Bruce, not being total familar with your set up. When I had my catalina Capri 26 I had a similar situation. What I did on mine was to make sure that ihad the wooden pad position over the uprite, at the Tee. I was supporting a mariner 5hp and never had any problems with it.
muised
Aug 17, 2005
97
- - Halifax, Nova Scotia
Wood bracket
I have an O'Day 25 with probably the same rail. You can purchase a bracket made for this purpose, or make one quite easily out of two 1 X 6 boards screwed together with cutouts for the rails. I personally would not worry about 50 lbs on the rail. If you are considering swapping your motor, you should have no problem. I use a Suzuki 2.2 hp outboard on my 9' inflatable (air floor) and it works fine. I would guess the 2.5 HP 4 stroke would have more power, and if planing is not a requirement I would go with the lightest outboard you can get away with.
