Dennis Brooks
I am trying to replace my stern light. When I took the old light off, the old wiring from the old light was still hooked up. When I saw this I decided to use this wiring. When I was working to hook up the new light, one wire broke loose from the splicing which is inside the boat. Hunter marine didn't give me any wire to pull out of the hole for the wiring of the new light either. I tried to find a easy way to get to the inside wiring on the starboard aft side of my boat. The only way that I can see to get to the wiring is to slide under the cockpit of the boat from inside(or underneath). I have one big problem. I am to big to slide under the cockpit. Does anyone on this forum have experience with a Hunter 23 1978 model? I am up to any suggestions on solving my problem.
