stern hardware fitting access
mike hill
I have refastened all the fittings in my 1983 Mac 25, but havent done the stern as it is sealed off from access. Does anyone know if this was considered in the construction? i would like to redo my tiller fittings and swim ladder, but dont know how i will hold the inside nuts!
Steve Paul
Mike here's an idea
Mike, I suggest you consider cutting access holes where possible. You can then finish the holes with access ports to keep the water out. Sorry I'm not familiar with your exact boat. Steve P.
Jun 13, 2004
97
Macgregor 25 Nevada City, CA
been done
http://archives.sailboatowners.com/pviewarch.htm?fno=80&sku=2004320170902.15&id=284692&ptl=#2004321013959.1 http://archives.sailboatowners.com/pviewarch.htm?fno=80&sku=2005236062558.80&id=300988&ptl=Block%20for%20Main%20Sheet%20Mac%2025&id=300988 couple of access threads from the archives Access holes from the cockpit really sound like a good idea to me.
Nov 17, 2004
104
Macgregor 25 Three Rivers, MI
other access
Mike, you can also do it without cutting any holes. There should be room in the starboard storage hatch to crawl back to the stern of the boat, but it is a tight fit. I took all of the flotation foam out from under the starboard seat and crawled in (I am 6ft 225lb) to tighten the nuts on the swim ladder I installed. Good luck. Chris 83' M25 Chara
