Mine has a cutlass bearing. I don't see why yours should not also. 1/8" gap is about right for a cutlass bearing tolerance. Looks like the yard forgot to reinstall yours. From: "brad_45@... [AlbinVega]"
AlbinVega@yahoogroups.com To:
AlbinVega@yahoogroups.com Sent: Saturday, April 15, 2017 4:56 PM Subject: [AlbinVega] Stern bearing, Cutlass bearing question
Hi, With a new stern bearing ordered from Vega Marin I showed up to the boat today with the proper allen wrenches to take off my stern bearing cover piece to see what I am up against. Several years ago a yard did an "adjustment" on the stern bearing which at the time took away the little bit of play the shaft had and I was told I didn't need a cutlass bearing (my fear at the time). I have developed the play again and now I am addressing it. When I took the gasket out of position and slid everything back on the shaft (prop not pulled yet) I was shocked to find massive play in all directions (1/8" or more). I realize the bronze piece fits into the fixed bronze piece and the gasket snugs it all but as I look to the back of the bearing I would expect to see something that resembled a cutlass bearing but I don't, just the back of the stern bearing receptacle and the 1/8"gap around the shaft. So my question is do Vega's have a cutlass bearing and mine is toast or has my boat been run for years without a Cutlass bearing and never knew it? I will try to get pics of my find. I fear I will be putting the yard owners kids through college on this. Any thoughts?BradV2548
#ygrps-yiv-1912138275 #ygrps-yiv-1912138275yiv3402675003 #ygrps-yiv-1912138275yiv3402675003 --
#ygrps-yiv-1912138275yiv3402675003ygrp-mkp {
border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;}
#ygrps-yiv-1912138275 #ygrps-yiv-1912138275yiv3402675003 #ygrps-yiv-1912138275yiv3402675003ygrp-mkp hr {
border:1px solid #d8d8d8;}
#ygrps-yiv-1912138275 #ygrps-yiv-1912138275yiv3402675003 #ygrps-yiv-1912138275yiv3402675003ygrp-mkp #ygrps-yiv-1912138275yiv3402675003hd {
color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;}
#ygrps-yiv-1912138275 #ygrps-yiv-1912138275yiv3402675003 #ygrps-yiv-1912138275yiv3402675003ygrp-mkp #ygrps-yiv-1912138275yiv3402675003ads {
margin-bottom:10px;}
#ygrps-yiv-1912138275 #ygrps-yiv-1912138275yiv3402675003 #ygrps-yiv-1912138275yiv3402675003ygrp-mkp .ygrps-yiv-1912138275yiv3402675003ad {
padding:0 0;}
#ygrps-yiv-1912138275 #ygrps-yiv-1912138275yiv3402675003 #ygrps-yiv-1912138275yiv3402675003ygrp-mkp .ygrps-yiv-1912138275yiv3402675003ad p {
margin:0;}
#ygrps-yiv-1912138275 #ygrps-yiv-1912138275yiv3402675003 #ygrps-yiv-1912138275yiv3402675003ygrp-mkp .ygrps-yiv-1912138275yiv3402675003ad a {
color:#0000ff;text-decoration:none;}
#ygrps-yiv-1912138275 #ygrps-yiv-1912138275yiv3402675003 #ygrps-yiv-1912138275yiv3402675003ygrp-sponsor #ygrps-yiv-1912138275yiv3402675003ygrp-lc {
font-family:Arial;}
#ygrps-yiv-1912138275 #ygrps-yiv-1912138275yiv3402675003 #ygrps-yiv-1912138275yiv3402675003ygrp-sponsor #ygrps-yiv-1912138275yiv3402675003ygrp-lc #ygrps-yiv-1912138275yiv3402675003hd {
margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;}
#ygrps-yiv-1912138275 #ygrps-yiv-1912138275yiv3402675003 #ygrps-yiv-1912138275yiv3402675003ygrp-sponsor #ygrps-yiv-1912138275yiv3402675003ygrp-lc .ygrps-yiv-1912138275yiv3402675003ad {
margin-bottom:10px;padding:0 0;}
#ygrps-yiv-1912138275 #ygrps-yiv-1912138275yiv3402675003 #ygrps-yiv-1912138275yiv3402675003actions {
font-family:Verdana;font-size:11px;padding:10px 0;}
#ygrps-yiv-1912138275 #ygrps-yiv-1912138275yiv3402675003 #ygrps-yiv-1912138275yiv3402675003activity {
background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;}
#ygrps-yiv-1912138275 #ygrps-yiv-1912138275yiv3402675003 #ygrps-yiv-1912138275yiv3402675003activity span {
font-weight:700;}
#ygrps-yiv-1912138275 #ygrps-yiv-1912138275yiv3402675003 #ygrps-yiv-1912138275yiv3402675003activity span:first-child {
text-transform:uppercase;}
#ygrps-yiv-1912138275 #ygrps-yiv-1912138275yiv3402675003 #ygrps-yiv-1912138275yiv3402675003activity span a {
color:#5085b6;text-decoration:none;}
#ygrps-yiv-1912138275 #ygrps-yiv-1912138275yiv3402675003 #ygrps-yiv-1912138275yiv3402675003activity span span {
color:#ff7900;}
#ygrps-yiv-1912138275 #ygrps-yiv-1912138275yiv3402675003 #ygrps-yiv-1912138275yiv3402675003activity span .ygrps-yiv-1912138275yiv3402675003underline {
text-decoration:underline;}
#ygrps-yiv-1912138275 #ygrps-yiv-1912138275yiv3402675003 .ygrps-yiv-1912138275yiv3402675003attach {
clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;}
#ygrps-yiv-1912138275 #ygrps-yiv-1912138275yiv3402675003 .ygrps-yiv-1912138275yiv3402675003attach div a {
#ygrps-yiv-1912138275 #ygrps-yiv-1912138275yiv3402675003 .ygrps-yiv-1912138275yiv3402675003attach img {
border:none;padding-right:5px;}
#ygrps-yiv-1912138275 #ygrps-yiv-1912138275yiv3402675003 .ygrps-yiv-1912138275yiv3402675003attach label {
display:block;margin-bottom:5px;}
#ygrps-yiv-1912138275 #ygrps-yiv-1912138275yiv3402675003 .ygrps-yiv-1912138275yiv3402675003attach label a {
#ygrps-yiv-1912138275 #ygrps-yiv-1912138275yiv3402675003 blockquote {
margin:0 0 0 4px;}
#ygrps-yiv-1912138275 #ygrps-yiv-1912138275yiv3402675003 .ygrps-yiv-1912138275yiv3402675003bold {
font-family:Arial;font-size:13px;font-weight:700;}
#ygrps-yiv-1912138275 #ygrps-yiv-1912138275yiv3402675003 .ygrps-yiv-1912138275yiv3402675003bold a {
#ygrps-yiv-1912138275 #ygrps-yiv-1912138275yiv3402675003 dd.ygrps-yiv-1912138275yiv3402675003last p a {
font-family:Verdana;font-weight:700;}
#ygrps-yiv-1912138275 #ygrps-yiv-1912138275yiv3402675003 dd.ygrps-yiv-1912138275yiv3402675003last p span {
margin-right:10px;font-family:Verdana;font-weight:700;}
#ygrps-yiv-1912138275 #ygrps-yiv-1912138275yiv3402675003 dd.ygrps-yiv-1912138275yiv3402675003last p span.ygrps-yiv-1912138275yiv3402675003yshortcuts {
margin-right:0;}
#ygrps-yiv-1912138275 #ygrps-yiv-1912138275yiv3402675003 div.ygrps-yiv-1912138275yiv3402675003attach-table div div a {
#ygrps-yiv-1912138275 #ygrps-yiv-1912138275yiv3402675003 div.ygrps-yiv-1912138275yiv3402675003attach-table {
width:400px;}
#ygrps-yiv-1912138275 #ygrps-yiv-1912138275yiv3402675003 div.ygrps-yiv-1912138275yiv3402675003file-title a, #ygrps-yiv-1912138275 #ygrps-yiv-1912138275yiv3402675003 div.ygrps-yiv-1912138275yiv3402675003file-title a:active, #ygrps-yiv-1912138275 #ygrps-yiv-1912138275yiv3402675003 div.ygrps-yiv-1912138275yiv3402675003file-title a:hover, #ygrps-yiv-1912138275 #ygrps-yiv-1912138275yiv3402675003 div.ygrps-yiv-1912138275yiv3402675003file-title a:visited {
#ygrps-yiv-1912138275 #ygrps-yiv-1912138275yiv3402675003 div.ygrps-yiv-1912138275yiv3402675003photo-title a, #ygrps-yiv-1912138275 #ygrps-yiv-1912138275yiv3402675003 div.ygrps-yiv-1912138275yiv3402675003photo-title a:active, #ygrps-yiv-1912138275 #ygrps-yiv-1912138275yiv3402675003 div.ygrps-yiv-1912138275yiv3402675003photo-title a:hover, #ygrps-yiv-1912138275 #ygrps-yiv-1912138275yiv3402675003 div.ygrps-yiv-1912138275yiv3402675003photo-title a:visited {
#ygrps-yiv-1912138275 #ygrps-yiv-1912138275yiv3402675003 div#ygrps-yiv-1912138275yiv3402675003ygrp-mlmsg #ygrps-yiv-1912138275yiv3402675003ygrp-msg p a span.ygrps-yiv-1912138275yiv3402675003yshortcuts {
font-family:Verdana;font-size:10px;font-weight:normal;}
#ygrps-yiv-1912138275 #ygrps-yiv-1912138275yiv3402675003 .ygrps-yiv-1912138275yiv3402675003green {
color:#628c2a;}
#ygrps-yiv-1912138275 #ygrps-yiv-1912138275yiv3402675003 .ygrps-yiv-1912138275yiv3402675003MsoNormal {
margin:0 0 0 0;}
#ygrps-yiv-1912138275 #ygrps-yiv-1912138275yiv3402675003 o {
font-size:0;}
#ygrps-yiv-1912138275 #ygrps-yiv-1912138275yiv3402675003 #ygrps-yiv-1912138275yiv3402675003photos div {
float:left;width:72px;}
#ygrps-yiv-1912138275 #ygrps-yiv-1912138275yiv3402675003 #ygrps-yiv-1912138275yiv3402675003photos div div {
border:1px solid #666666;height:62px;overflow:hidden;width:62px;}
#ygrps-yiv-1912138275 #ygrps-yiv-1912138275yiv3402675003 #ygrps-yiv-1912138275yiv3402675003photos div label {
color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;}
#ygrps-yiv-1912138275 #ygrps-yiv-1912138275yiv3402675003 #ygrps-yiv-1912138275yiv3402675003reco-category {
font-size:77%;}
#ygrps-yiv-1912138275 #ygrps-yiv-1912138275yiv3402675003 #ygrps-yiv-1912138275yiv3402675003reco-desc {
font-size:77%;}
#ygrps-yiv-1912138275 #ygrps-yiv-1912138275yiv3402675003 .ygrps-yiv-1912138275yiv3402675003replbq {
margin:4px;}
#ygrps-yiv-1912138275 #ygrps-yiv-1912138275yiv3402675003 #ygrps-yiv-1912138275yiv3402675003ygrp-actbar div a:first-child {
margin-right:2px;padding-right:5px;}
#ygrps-yiv-1912138275 #ygrps-yiv-1912138275yiv3402675003 #ygrps-yiv-1912138275yiv3402675003ygrp-mlmsg {
font-size:13px;font-family:Arial, helvetica, clean, sans-serif;}
#ygrps-yiv-1912138275 #ygrps-yiv-1912138275yiv3402675003 #ygrps-yiv-1912138275yiv3402675003ygrp-mlmsg table {
font-size:inherit;font:100%;}
#ygrps-yiv-1912138275 #ygrps-yiv-1912138275yiv3402675003 #ygrps-yiv-1912138275yiv3402675003ygrp-mlmsg select, #ygrps-yiv-1912138275 #ygrps-yiv-1912138275yiv3402675003 input, #ygrps-yiv-1912138275 #ygrps-yiv-1912138275yiv3402675003 textarea {
font:99% Arial, Helvetica, clean, sans-serif;}
#ygrps-yiv-1912138275 #ygrps-yiv-1912138275yiv3402675003 #ygrps-yiv-1912138275yiv3402675003ygrp-mlmsg pre, #ygrps-yiv-1912138275 #ygrps-yiv-1912138275yiv3402675003 code {
font:115% monospace;}
#ygrps-yiv-1912138275 #ygrps-yiv-1912138275yiv3402675003 #ygrps-yiv-1912138275yiv3402675003ygrp-mlmsg * {
line-height:1.22em;}
#ygrps-yiv-1912138275 #ygrps-yiv-1912138275yiv3402675003 #ygrps-yiv-1912138275yiv3402675003ygrp-mlmsg #ygrps-yiv-1912138275yiv3402675003logo {
padding-bottom:10px;}#ygrps-yiv-1912138275 #ygrps-yiv-1912138275yiv3402675003 #ygrps-yiv-1912138275yiv3402675003ygrp-msg p a {
font-family:Verdana;}
#ygrps-yiv-1912138275 #ygrps-yiv-1912138275yiv3402675003 #ygrps-yiv-1912138275yiv3402675003ygrp-msg p#ygrps-yiv-1912138275yiv3402675003attach-count span {
color:#1E66AE;font-weight:700;}
#ygrps-yiv-1912138275 #ygrps-yiv-1912138275yiv3402675003 #ygrps-yiv-1912138275yiv3402675003ygrp-reco #ygrps-yiv-1912138275yiv3402675003reco-head {
color:#ff7900;font-weight:700;}
#ygrps-yiv-1912138275 #ygrps-yiv-1912138275yiv3402675003 #ygrps-yiv-1912138275yiv3402675003ygrp-reco {
margin-bottom:20px;padding:0px;}
#ygrps-yiv-1912138275 #ygrps-yiv-1912138275yiv3402675003 #ygrps-yiv-1912138275yiv3402675003ygrp-sponsor #ygrps-yiv-1912138275yiv3402675003ov li a {
font-size:130%;text-decoration:none;}
#ygrps-yiv-1912138275 #ygrps-yiv-1912138275yiv3402675003 #ygrps-yiv-1912138275yiv3402675003ygrp-sponsor #ygrps-yiv-1912138275yiv3402675003ov li {
font-size:77%;list-style-type:square;padding:6px 0;}
#ygrps-yiv-1912138275 #ygrps-yiv-1912138275yiv3402675003 #ygrps-yiv-1912138275yiv3402675003ygrp-sponsor #ygrps-yiv-1912138275yiv3402675003ov ul {
margin:0;padding:0 0 0 8px;}
#ygrps-yiv-1912138275 #ygrps-yiv-1912138275yiv3402675003 #ygrps-yiv-1912138275yiv3402675003ygrp-text {
font-family:Georgia;}
#ygrps-yiv-1912138275 #ygrps-yiv-1912138275yiv3402675003 #ygrps-yiv-1912138275yiv3402675003ygrp-text p {
margin:0 0 1em 0;}
#ygrps-yiv-1912138275 #ygrps-yiv-1912138275yiv3402675003 #ygrps-yiv-1912138275yiv3402675003ygrp-text tt {
font-size:120%;}
#ygrps-yiv-1912138275 #ygrps-yiv-1912138275yiv3402675003 #ygrps-yiv-1912138275yiv3402675003ygrp-vital ul li:last-child {
border-right:none !important;}
