I ahve a Catalina 30 and will be heading to desolation sound in august and was wondering what is the recommended size of line for tieing off to the shore in a polypropelyn line
The stern line doesn't need to be as strong as the anchor line since it should be doubled. Taking both ends back to the boat cleats allows you to cast off at low tide when you can't reach the ring/tree/log or whatever, by just casting one end free and let it run while hauling on the other end. When mooring beware of possible reversing or other cross currents which can load up your lines and drag your anchor causing you to swing into the shore at 2am.I ahve a Catalina 30 and will be heading to desolation sound in august and was wondering what is the recommended size of line for tieing off to the shore in a polypropelyn line
