Some Help
Bill, when I step my mast I start with the mast laying down with the top to the aft.Attach all Shrouds except the forestay and the two front lower shrouds. Now put the bottom set of holes (Mine are just notchs) in the mast step and put in the bolt. Lift from the aft while someone pulls(Mostly Balances) with the 3 forward shrouds from the bow(Gloves needed). Get the mast as high as you can from the cockpit and walk your way up on to the cabin roof. then with the mast on your shoulder walk straight forward until the forestay can be connected then the other shrouds. Watch all the shrouds on the lifelines while lifting. You can make or buy a Mast step do-hickey that sits on your gudgeons and Supports the mast at the level which you can start from the cabin roof. Also, I have used a block attached to the forestay chainplate and attached the other side to the forestay itself to aid in pulling the the mast up, when I was solo once (I Do Not recommend the SOLO part at all!).
