With a little practice.....
it gets easier.  I have a DaySailer I, 1966, with a one piece mast, NOT one with a tabernacle hinge.  I have to do a balancing act to get the mast up right, and into the hole on top of the cuddy, then once through the hole I have to find the mast step by feel.  I have always done this solo and each time it seems to get a little easier.  The biggest problem is on WINDY days.I start with the foot of the mast against the wheel of my trailer and walk the mast into an upright position.  Then I am able to keep a grip on the mast as I step onto the boat and get to the top of the cuddy. I then get a good grip on the mast, right hand as far up the mast as possible, left hand lifting the mast onto the boat.  Then I walk the mast (this is the tricky part on windy days), little hops at a time to the hole.  Once you get the mast into the hole it is much easier to keep it balanced.  Then it is a matter of feeling for th mast step.  If you are having a lot of trouble finding it, you can let the mast foot  slip to the very bottom of the boat, keep a hand on the mast to feel if it is leaning to far, and slowly kneel down and get a peek of where the mast is in relation to the mast step.  Once you get your bearings on that point, then usually with in a couple of tries the mast can be slipped over the mast step.  This is all not as hard as it sounds.  That is the way I accomplish the stepping of the mast.  I have been trying to figure out an easier way, but as of yet I haven't.  If you or anyone else has a suggestion it would be greatly appreciated.  Like Roger, I am an out-of-shape 57 year old, 195 lbs.  The main excercise I get is a daily walk with the dog, and clicking a computer mouse in the evening while clicking the TV remote.  ( good coordination eh ??)Unstepping the mast is much easier and faster, and I have only lost balance of the mast once.  Once you get the mast lifted out of the cuddy hole, just lift the mast off the top of the cuddy, and just let it slide through your hands till the base of the mast hits the ground.  I usually have a life vest or something for the mast to rest on so not to accidentally hit a rock or concrete that might damage the foot of the mast.As I said, with a little practice it becomes much easier than it sounds in my response.Fair Winds,Gary"Dancing Girls II"
