Russ
I recently took a class on sailing where they strongly recommended using a winch to raise the mast. My wife and I successfully stepped our mast the first time in our driveway within 45 minutes (not including rigging the sails) but I'm curious about the winch. Is this a normal operation or even possible on the Hunter. Second question, if you step the mast after launching, how do you set up the standing rigging. I've been told you view from front and back to confirm perpendicular to the deck, but that view would be limited if you are in the water. Should I set it up and leave the rigging close to finals in the driveway so that after launching you simply attach the forestay and turn each turnbuckle a few even turns. As you can tell, I'm really new at this.
