Stepping Mast @ Hunter 25.5
L
Lee Taylor
Looking for all information on a easy mast stepping system. I heard of some web site instructions but have not been successfull. We intend to trailer more than average and do not always have extra muscle to raise mast.
Apr 19, 1999
1,670
Pearson Wanderer Titusville, Florida
Search the forum archives under H23
At least four mast-raising systems have been developed for the H23 by owners in this forum. Most have detailed photos in the Photo Forum as well. Select "23" for boat model, enter the key words "mast raising" and step back. With slight modifications for the slightly longer foredeck, any of the these systems should work for the 25.5. Good luck. Peter H23 "Raven"
Dave Busby
Just be careful...
I have lowered the mast on my 86' 25.5...but I had my two sons with me. The mast is not all that heavy, but it is very awkward to handle after the mid-way point down, or up. It is easy to let down, but harder to pull back up. You have to make sure that the shrouds don't get twisted or out of the spreader groves. I'm listed in the owners fine, give me a call if you want more info about the 25.. Dave Busby
Dave Weir
25.5 Mast
Further to Dave Busby's caution--the T-terminals on the uppers can easily get dislodged or rotated out of position when raising the mast. If this happens, it should be lowered again since it is not safe to climb without the uppers secure. Even using a gin pole, we have found it desireable to have an extra person maintain tension on the uppers until the mast is vertical. Good Luck!
