steering
2
We have a 33 O/I with hydraulic steering . How do you bleed the system? I have noticed some noise like air in the system. But it only makes the noise going one way and only if you are in a hurry. Turning it slow there is no noise. Thanks for your help. David
Sep 29, 2008
162
Morgan Out Island 33 Pompano Beach
Are you sure you need to bleed it. The fluid level may just be low. Look at the resouivor(sp) located on the bulkhead of the stbd lazarette. The clear plastic tube shows the fluid level. If it is more than 2" from the top. unscrew the top, add fluid, put the top on and repressurize. Bob
