Steering Wheel Shaft & Key - Need a Stop position
Sep 1, 2014
39
Catalina 30 MKII Gulfport, FL
Replaced my Raymarine autopilot steering wheel assembly. Old one hadn't worked since I bought the boat. Issue: the steering wheel has no "stop" to it, with shaft key a rectangle with no slope, (am used to shaft keys sloped that create a stopping point - for securing nut to press against). Without a "stop" the only stopping point is the Binnacle Raymarine post used to keep autopilot from turning. Can't have that plastic wheel be the stop for the wheel - it's not intended for that, and don't want the post post pushing against the plastic wheel.
Looks like my only alternatives are a PVC spacer between the wheel and binnacle, which isn't ideal (see picture), or have a shaft key made that slopes. Other ideas? Ignoring the autopilot, what was the factory answer to this? Is this an Edson question / solution?
stopping
heel will slide inNow I need to ensure the wheel stops
Jun 20, 2021
53
Catalina '83 30 SR Universal 5411 Arkansas River>Caribbean
The shaft on my '83 Edson has a shoulder that stops the wheel from sitting deeper.
Jun 2, 2014
603
Catalina 30 mkII - 1987 Alamitos Bay Marina, LB, CA
You're right. Talked w Edson. They also put a washer on the outside of the Snap Ring to distribute the pressure.
Ah... I don't have a secondary washer, just the snap ring. That makes sense now. I'll add a washer.
