Has anyone replaced the steering cable lately and can direct me to a supplier? Hunter no longer carries the chain or steering cable going to the steering quadrant on this boat. The cable has frayed at the bronze turning block before ending into the quadrant. Edson Co. sells a kit but the cable ends do not have adjusting screws made into the cable as the original. They are cut ends which will require thimble, locking cable device and then a eye screw. Just more connections that can come loose or require adjustment as it comes under tension. Before I buy from Edson, any lead to a vendor that can get me to something more like what came with the boat is appreciated.
