F
		Francois Machabee
Hello again,I have need for some information on the steering setup on the Oday37CC.  My Edson pedestal leads two black cables with the SS cable inside through the engine compartment, out via the port side in the AFT cabin via the locker and finally under the AFT berth to the rudder wheel attachment.  Both cables go through, side by side via a sort of large white plastic hollowed-out bolt through which the SS cable runs and turns towards the wheel.One of the plastic bolt is broken and the SS cable now chafes directly against the metal bolt holder and is starting to show some signs of wear (a few strands are broken).  Does anyone know where I can find these and if not, if I can use a turning block instead?  I know D&R might have them and I will call.Also, I noticed some water at the base of the rudder stock.  Is this normal?Thanks!
