Steel Keel...spots of rust etc...
Paul Bradbury
After haulout this fall I noticed about 12 very minor spots of rust on the keel. Should I do anything about this for next spring? I was thinking sanding down to the steel, re-gelcoat, and then bottom paint to finish. There are numerous 1/4" bumps that if I push will bleed out some nasty smelling fluid. It might mean that I refinish the entire keel. Comments and suggestions would be appreciated.
L
larry w.
keel rust
Paul; On my Bene, I get several rusty spots each haulout. I sand down each spot, apply two coats of epoxy, bottom paint, splash. The leaking bumps are blisters. I give them the same treatment.
